shogs Posted July 22, 2009 Report Posted July 22, 2009 Ever since its gotten a little bit over 70 degrees my bikes had no top end and I bog a lot and leave a trail of smoke behind me (not horrible just seems rich) My mods are hjr aggressive trail port, +4 timing, vf3's, pro design 22cc domes, pt mids and a 2-1 carb at sea level. I'm currently running high octane. My jetting was 195 but I dropped to a 188 and still no luck, 45 pilot (if i remember correctly, and I think a eek needle (maybe snop can chime in because he helped me out with it earlier. Sometimes there is a little bit of bog of a rolling start but nothing too bad so low end seems to be decent. My shop charges about 5 bucks a needle and i'm going to aruba for a week so would like to order the needles while i'm here. My idle screw is screwed almost all the way in so could that have anything to do with it? I might check my timing plate to make sure its still at +4 and the loctite is holding. Also after I rev my it seems like something is vibrating (almost like a metal vibrating). I just don't want to fuck my new top end before I even get to rip on it this summer. Let me know if theres anything else I need to let you guys know. Also I might switch back to stockers or 28's when I get around to it. I just want to add that when I hit the throttle 5/8 and w.o.t are about the same power wise. The more gas I give it the louder it gets but no more power. Thanks cody Quote
AKheathen Posted July 22, 2009 Report Posted July 22, 2009 keep going down, and run some new fuel if it's a little old. you don't need higher octane and will probably loose some power. try a 50/50 mix or less. airscrews wanting to be that far in means that you need to up the pilot. also, make all adjustments for the bike at operating temperature. Quote
