A comlpte banshee and a 421 cub ported
lewisyfz450
I have a complte J arm 87 banshee that runs really hard for what it is. it has all new bearints seals and bushings everywhere. It has a new chain new cluch and thorttle cable new just buffd tires all around they are 21 x 7 x 10 mohawk front 22 x 12 x 8 12 paddles 78 roll out on back. It has T6 pipes on it. the motor has a trud and wielded crank with longer rods with 67 mm bore with stock cylinders that are a dune drag portt by andy from m&m it has a new cluch with a billet basket a new trany a cool head. andy told me that with 35mm carbs and v3 reeds it would make 65 70 hp right now i have stock reeds and carbs and that makes a lot more torque you can fell the difference. the bike has dragon glass plastic
The 421 cub is a 68mm bore with a 4 mil crank and cub cylinders the motor was build and ported by Matt Haynes and had it in a bike of his and it ran low 3.90s and high 3.80s My best time at atoka was a 4.002 and im a 185 lbs rider and not a great one
http://forums.[censord].com/index.php?...=4253&st=20
it has a lockup and billet cover and a billet water pump cover and flywheel cover. It has a 1-5 neatural down override it does not have intakes and carbs but it does have reeds that was custom made for it. i dont know what the domes or but they are for alky the squish is 47 and 45 right where matt still want it at the motor has low hours on the new pistons
I would like to trade for
1 Cash
2 250r 4 wheeler (88)
3 250r 4 wheeler (86)
4 Grizzly 660 or 700
5 Grizzly 350
http://www.bansheehq.com/forums/index.php?...p;#entry1022303
http://forums.atvdragracers.com/index.php?...=4253&st=20
1 Cash i would like 3000 for the banshee and 2400 for the motor but times are hard i know so talk and see what we can do
5 Grizzly 350
