bakersfieldturbo Posted June 23, 2009 Report Posted June 23, 2009 ok guys im a newbie to banshees... but everything i need to know about banshees hq has the answers ... so my question is do i need to rejet after putting on a new head, +4 timing , and some Vf2?? and if i happen to put on some power pros drag pipes would i have to rejet ?? or can i even work with drag pipes with a single carb? Quote
XxMeltIcexX Posted June 23, 2009 Report Posted June 23, 2009 You have to jet for any fuel/air mixture flow change. The more air flow the more fuel you need. You can use a single carb setup, but for dragging dual carbs are recommended. Quote
bakersfieldturbo Posted June 23, 2009 Author Report Posted June 23, 2009 how many jets up would i have to go cause im pretty sure i got a 200 main . inless i read it wrong or grab the wrong jet .. but i asked the people here about running the drag pipes and the vf2 reeds. and he told me to get 200- 205 and try them all but that sounded weird ... so im thinking whos beeter to ask then hq?? You have to jet for any fuel/air mixture flow change. The more air flow the more fuel you need. You can use a single carb setup, but for dragging dual carbs are recommended. Quote
XxMeltIcexX Posted June 23, 2009 Report Posted June 23, 2009 I see its a 38mm pwk. I don't know much about single carbs, but someone will chime in. Quote
