are there cool heads or pro design etc billet heads for big bores?I have a 72mm 4 mil long rod stroker and im thinking about adding a bit of bling and tunability to my shee.Are oring head gaskets better than copper ones?just curious as this is my first banshee,got the bugs FINALLY worked out on my cannondale and felt it was time for another oil burner.
What you do is buy a cool head then get big bore domes for it. Call jeff at F.A.S.T. he's one of the site sponsors. And it uses rubber o-rings that are much better, yes. The can be re-used alot of the time and the are more durable and last longer
Remeasure that cylinder.
If it's a supercub, you can get a NOSS head made for the super cub.
If it's a stock cylinder...good luck.
I know at 68mm on a stock head there is paper thin material between the Oring groove and the head stud.
ON an aftermarket head, stock stud design, not a ton of room either between the dome and stud.
Make sure you do in fact have a 72mm piston, then give Dave Noss a call to help you out.
I got a feeling you're just gonna have to run your stock head with a copper gasket.
And if that's the case, get your stock head polished for the bling.
Have it smoothed over, nubs and fins taken off, and polished. They actually turn out pretty nice!
