GrMeyer Posted June 14, 2009 Report Share Posted June 14, 2009 Well after getting my jugs ported I went riding and I shifted down from 6th to 5th to turn a corner and it just dies. Pulled the head and the crank turns ok. Put it up on blocks and put it in 1st with head off and try to turn the tires and NO GO!!! anyone had this Prob? Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted June 14, 2009 Report Share Posted June 14, 2009 Pull the clutch cover and make sure nothing is broken in there. Will it kick over? Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted June 14, 2009 Author Report Share Posted June 14, 2009 Yeah that was the first place I checked was in the clutch side cover... and no it will not kick over Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted June 14, 2009 Report Share Posted June 14, 2009 With the clutch cover off turn everything that the kicker would turn if you kicked it if that makes sense. With the clutch basket off will the crank spin? Will the tranny input shaft turn in N? Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted June 14, 2009 Author Report Share Posted June 14, 2009 well the clutch basket is still on and I can take and spin the crank with the trans in (N) but put it into gear and nothing!!! Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted June 14, 2009 Report Share Posted June 14, 2009 Well hell. I'm not good at helping fix anything without touching it. You were able to shift thru the gears thought with the engine off, right. Take your chain off and your sure that your axle spins. I'm all over the place, just thinking about different things. Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted June 14, 2009 Author Report Share Posted June 14, 2009 Yup axle spins because i had to get towed back to my truck. It will shift through all gears sitting still. When I drained the trans oil I didnt see any metal or shavings or peaces Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted June 14, 2009 Report Share Posted June 14, 2009 Well time to split the cases it sounds like. Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted June 14, 2009 Author Report Share Posted June 14, 2009 Well time to split the cases it sounds like. I know...I dont want to because it just got put back together.... and have another motor I have to tear down...Seems like it is a bad year for me and quads but the other one is a easy fix...had a bolt break off so i have to pull the head and jug and thats about it.. Just time Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted June 16, 2009 Author Report Share Posted June 16, 2009 anyone know a way to mod the stock trans without just the normal little stuff like the shift star...as in beefing it up Quote Link to comment Share on other sites More sharing options...
