Hey I bought a clutch kit from Jeff at F.A.S.T. and I am currently installing it. I noticed the clutch that was in my Banshee (not sure what kind it is) has the rubber cushion rings between the steel plates under the friction plates. It appears that they will not fit with the new clutch because the new friction plates have a larger area. I assume they are not supposed to be used with the new clutch, am I correct? Thanks a lot.
Darren
Okay thanks a lot. I was pretty sure the clutch kit was a complete kit, just wanted to make sure.
