90Bansheedude Posted June 5, 2009 Report Posted June 5, 2009 I made a post already, but i couldn't figure out how to change the title, cause i named it cheap banshee mods, and thats not even close to what I am wanting, and i figured it would get lost because everyone wants cheap mods. I am curious what I ended up with, and what i should do. http://www.bansheehq.com/forums/index.php?...=116263&hl= Theres the link to the previous post, if it should be moved, thats fine. If I shouldn't have posted here to, I apologize, and Mods you can delete it. I just need to know what I should do! I dont want to spend alot of extra money, (keep it cheap), but with the mods it has already, I dont want to waste them by not using some of their potential. Any ideas what i should buy, or not buy? Thanks guys, i really appreciate it! Brian =) Quote
brugal Posted June 5, 2009 Report Posted June 5, 2009 I am curious what I ended up with, and what i should do. http://www.bansheehq.com/forums/index.php?...=116263&hl= Theres the link I just need to know what I should do! I dont want to spend alot of extra money, (keep it cheap), Seems like you bought a shee thats ready to be parted out and sold. That link is a long read. Rebuild the top end, advance the timing and buy used parts from the for sale forum here on the HQ. Quote
90Bansheedude Posted June 5, 2009 Author Report Posted June 5, 2009 (edited) Seems like you bought a shee thats ready to be parted out and sold. That link is a long read. Rebuild the top end, advance the timing and buy used parts from the for sale forum here on the HQ. yeah, sorry about the long read. I picked it up for $260. I hate to part it out with all those nice parts though. Any idea why they would have had it at - 1 1/2 degrees? Edited June 5, 2009 by 90Bansheedude Quote
brugal Posted June 5, 2009 Report Posted June 5, 2009 I picked it up for $260. I hate to part it out with all those nice parts though. Any idea why they would have had it at - 1 1/2 degrees? 260 is sweet, hell the front shocks cost more then that. "-1 1/2 degrees" maybe its loose and the vibration moved it in the negative direction :shrug: Quote
90Bansheedude Posted June 5, 2009 Author Report Posted June 5, 2009 260 is sweet, hell the front shocks cost more then that. "-1 1/2 degrees" maybe its loose and the vibration moved it in the negative direction :shrug: Thanks Brugal, I appreciate the suggestions!, Ya i know, I looked on the website (of course mine aren't new) and about shat myself when it said $1k for 2 shocks! (thats also why my post was so long, i was excited! :biggrin: ) It doesn't look like the stator could have moved, and its tight!, but i suppose its possible. Or they just didn't have a clue were to set it? Does this sound like a good plan? Clean the cases out fromt he melted piston, reassemble with new pistons and a hone job (cylinder measures approx 64.80), find out what compression is with the stock style head (any specs so i can check if its been milled) to see what I need to run for gas (91 is all that is at the pump, but I may be able to get leaded AV gas, is it good to use?) Put timing at +4, Change the jets in the stock carbs ( to what, i dont know yet, has k&n and bills pipes, and im in Nebraska). And it should be a decent runner. Sound good? Or should I put domes or mill the head if its not? Im going to be trail riding and some flat land playing and sand drags. Quote
