4strokekilla5 Posted May 17, 2009 Report Posted May 17, 2009 i remebering seeing a thread about home polishing a clutch cover to look chrome but i have no luck finding it. can anyone help Quote
2/2 many banshees Posted May 17, 2009 Report Posted May 17, 2009 i remebering seeing a thread about home polishing a clutch cover to look chrome but i have no luck finding it. can anyone help it takes a lot of time if I did it again I'd just buy one Quote
4strokekilla5 Posted May 17, 2009 Author Report Posted May 17, 2009 it takes a lot of time if I did it again I'd just buy one well i already have the clutch cover off and the paint stripped of with aircraft alluminum paint remover. i just want to know how to make it really shine Quote
2001Stroker Posted May 17, 2009 Report Posted May 17, 2009 it takes a lot of time if I did it again I'd just buy one True that. It sucks. It takes alot of sanding, because it's cast. I started with 120 grit, then 220, 300, 400, and 600. Then I used steel wool. Started with #2, then #0, #00, #000, #0000. Then you can bring it to the buffing wheel. I used the Dremel tool first, in all of the corners, and hard to reach spots. The big areas, I did with the bench polisher. I use stainless compound. Quote
