wobbly Posted May 17, 2009 Report Posted May 17, 2009 Running 485 Cheetah, one on 95Pump the other 110 Race gas, anyone tell me what dome volumes are successfull/safe - thanks Quote
Onesickcrewcab Posted May 17, 2009 Report Posted May 17, 2009 Running 485 Cheetah, one on 95Pump the other 110 Race gas, anyone tell me what dome volumes are successfull/safe - thanks Depends on your elevation. My 485 at sea level had 24cc domes and the compression was right at 200 PSI per cylinder. Right now I currently have 27cc domes and the compression is 175 PSI per cylinder. I have a 485 with powervalves blocked off. Even with 175 PSI you should be running 110 race gas. Quote
2001Stroker Posted May 17, 2009 Report Posted May 17, 2009 Depends on porting, elevation, timing, and a few other things to be able to point you in the right direction. I would say 29cc domes would be safe for pump gas. 27's might need somewhere around 104 octane, and 25's need 110 octane. Quote
wobbly Posted May 17, 2009 Author Report Posted May 17, 2009 You guys quote actual compression volume or to the top of the plug hole???? Quote
2001Stroker Posted May 17, 2009 Report Posted May 17, 2009 Me personally, I don't believe that cranking compression has anything to do with fuel requirements. Alot of people on here do. It's just a tool for figuring out when you need to do your topend. I go by compression ratios, and timing. Quote
wobbly Posted May 18, 2009 Author Report Posted May 18, 2009 Just been told that Mericans quote the volume of the domes chamber, so the effective volume ( to calculate actual com ratio) is less the piston volume, for the 485 around 7cc - correct??? Quote
