check the wires from the switch to the lights. unplug the connector for the kill/light switch, and ohm the green wire to each light, then the yellow. then ohm them to ground, you should get some resistance through the bulbs when you plug the light connectors back in @ the lights.next, make 2 jumpers. stick one in the black/white wire, so you can touch to the black wire as a kill switch. next, put the other in the yellow/red wire, and jump it to the green wire for low beam, and yellow for high. if all that checks out, then you have a bad switch.
