murphy Posted May 12, 2009 Report Posted May 12, 2009 Last week my headlights gave up on me, got 2 new bulbs today. Only 1 light works and on that one light only low beam works. Any help appreciated Quote
AKheathen Posted May 12, 2009 Report Posted May 12, 2009 check the wires from the switch to the lights. unplug the connector for the kill/light switch, and ohm the green wire to each light, then the yellow. then ohm them to ground, you should get some resistance through the bulbs when you plug the light connectors back in @ the lights.next, make 2 jumpers. stick one in the black/white wire, so you can touch to the black wire as a kill switch. next, put the other in the yellow/red wire, and jump it to the green wire for low beam, and yellow for high. if all that checks out, then you have a bad switch. Quote
lowbuckracing Posted May 13, 2009 Report Posted May 13, 2009 Were the bulbs bad when you pulled them?,As in pop..No more wires going across? Quote
