I'm wondering if someone know how to remove the clutch actuator needle bearing, the bearing that hold the clutch level arm (attached to the cable on the case).
I'm in the way to rebuilt my engine case and I tried to remove the bearing with a rod and a hammer and then the needle baering failed in part. Now the outside needle bearing sleeve is stock in the case and I don't know how to remove it.
any help will help
Edited by Thewhite
