ok so i called hjr and gbot the prices and everything i guess what im trying to decide now, is what port job to get, im thinking dune/play port or the mx hardcore port, any suggestions? i ride trails the track and occasional drag, but not much, but when i do drag i do not wanna lose, what would put out more power, dune/play or mx hardcore? do they have the same power and the power band is different or does one put out alot more power? and the piston cutting and port casing what is that? and does it produce more power? im clueless guys just some opinions if yall dont mind, yall havent steered me wrong yet!
also i saw dude below me was talking about his crank seal leaking, i think mine is leaking too, when i do the port job and new top end i should prob change that as well while everything is torn down. also i think i might have some antifreeze leaking into my motor like i think the exhaust smells kinda maple syrupy ha, could it be leaking like into the pistons? thanks again yall
The difference between the Dune and MX port is where the power is going to peak at in the RPM range.
The dune is more of a top end power port,the mx is lower in the rpm range. the mx port will have more grunt. the dune will probably have more peak horespower,but it will be high rpm power.
As for your crank seal,i would be sure its leaking before i did a complete teardown,thats a lot of work.There are ways to check that do a leak test.
If antifreaze is getting into your combustion chamber,its probably the head gasket
Edited by Burt Reynolds
sweet and if its not leaking tooo bad shoudl i leave it alone also, and when i get the new top end in they will put a new head gasket in right?
i wonder if hjr has like power curves for each port job he could show me or something, and what does piston cutting and port casing do?
If you tear it down and do all that porting and stuff you should get your crank true and welded. Always replace stuff up the to point that you have taken it apart, like if you do the top end then replace all gaskets and seals in the top end. the dune port will be better for your drag racing but your mx port will be better for most of your riding since you do mostly trails and track, Kevin should be able to tell you what is best if you tell him what your doing. The case porting and piston cutting is just a way to match your internals a little better, and squeeze a little more power, I wouldn't really worry about it for and MX and trail bike
thats what kevin said but im not really a mechanic ha at all so id have to send him my entire motor, which with labor and him tearing everything apart would be a little out of my budget he said i didnt need to do it, and it was an insurance policy ha to make sure it didnt break, but how necessary is it do you think? it makes your crankshaft alot stronger right? and could i do it myself im just scared to pull this ish apart
