how can you tell if your crank is a stroker or not? besides measuring 53 to 58. or if your piston comes to the top of the cyclinder. my crank is a shiny steel color and it says hotrods on the sides.
measure from the crank centerline to the main pin and multiply X2 this will give you your stroke. Measure from eye center to eye center on the rod to get the rod length. 54mm stroke 110mm rod is stock.
