I know that this is different for each bike but the idle screws are complety out and I need a starting point. The bike has KN pods, FMF Fatties and that is it. Thanks.
what kind of idle screws with tors or not maybe motion pro?
As a rule of thumb on any carb I setup.
I look in the back of the carb, and in/out the idle screw until I can JUST see the slide start to move up.
I then turn it in 1.5 turns.
You can make 1/4 and 1/2 turn adjustments from there, remember....you want to set the idle while warm.
