robert0762 Posted February 26, 2009 Report Posted February 26, 2009 How does the float valve pin come out is it threaded or just slides out I just dont want to fuck something up taking it apart Quote
RUDEDAWG Posted February 26, 2009 Report Posted February 26, 2009 How does the float valve pin come out is it threaded or just slides out I just dont want to fuck something up taking it apart It only comes out one way, all you have to do is use a punch or something that is a little smaller diameter than the pin itself and tap it out VERY gently. :thumbsup: Quote
J-Madd Posted February 26, 2009 Report Posted February 26, 2009 It's been my experience that it falls out on its own at the most inconvenient time. I went to test and tune at a track, and decided to make some adjustments on my carbs overnight for the race the next day. Got called to the line and the bowl was pouring out fuel. Took it off and the pin was gone. A friend found it on the ground in the pits near the trailer. Don' t know how I got luck enough for that to be found. So to answer the question....Yeah, just use punch or paper clip or something, or just shake the carb and it will fall it most of the time. Quote
