Pro Design intakes. I had 34 PJs in them. I assume they will do a little over and under that.
Ported stock reed cages with Vito's 2 stage reeds.
Chromed reed spacers 5/16" thick.
Stock crossover tube to fit on intakes. It had the boost bottle on it when I got it. Trashed it and put this on with some hose. These are not VF3 compatible. That's why I'm selling. I just bought new intakes and need to pay for them. Would like to get 160.00 shipped out of all of it plus paypal fees. May swap for some BLING. Or something else I don't have. Let me know.
Edited by dave5.0
Not to jack your thread bud, but i run these same intakes WITH VF3's. All you have to do is cut the lil fin off the bottom and a tiny lil bit of grinding or sanding off the intakes and the V3's and PD intakes will match up perfectly! Running this way for a few years now! So easy a cave man can do it :biggrin:
Just letting you know yo. :thumbsup:
Here is a pic of the bottom of mine after i was done doing it.(Takes 5 minutes to do) If you need to know exactly what to do PM me. Just think, now you don't have to sell them :beer:
http://i27.photobucket.com/albums/c164/sav.../Intakes003.jpg
And yes, the boost bottle is retarded and leaks through the rubber grommets, here is the way i eliminated my boost bottle also.
http://i27.photobucket.com/albums/c164/sav...emoval001-1.jpg
Good luck!
Edited by savage420
Good luck!
Ya I was going to do that. I was running a set of 34 with the plug welded up on the left one. Just picked up a set of 35 that have plugs. Kinda wanted to keep the plugs. I hate the stupid crossover tube. So I just bought a set of Boss intakes. Solved 3 problems at once. Now I need these to go away.
Thanks though.
