bamaboybv Posted February 17, 2009 Report Posted February 17, 2009 97 shee, wiseco std pistons. k n filter pods, asr pipes, timing advance, no tors, elevated 800 ft above sea level. boost bottle. I'm lean at 240 mains, and 30 pilots. pilots seem to be good, but lean on mid-top where should i start 300 maybe? Quote
rubberneck Posted February 17, 2009 Report Posted February 17, 2009 I dont know anything about asr pipes, but with k&n pods, T5s at sea level, i run 320-340 mains depending on temp and stock pilots (25) When you go way up on the main, you will probably find you need to drop the needle a clip or 2 and posibbly drop to a 27.5 pilot. Quote
bamaboybv Posted February 23, 2009 Author Report Posted February 23, 2009 I dont know anything about asr pipes, but with k&n pods, T5s at sea level, i run 320-340 mains depending on temp and stock pilots (25) When you go way up on the main, you will probably find you need to drop the needle a clip or 2 and posibbly drop to a 27.5 pilot. Sorry dude I meant i had a 27.5 pilot, but yea that sounds good. I run 93 octane and Ima try the 330's thanx Quote
