hey guys i have a 96 banshee with fmf sst pipes, power core 2 silencers, bored 40 over, ported, trinity stage 4 cool head with 20cc domes pro flow air filter, and removed airbox lid....anyone have any idea what size jets i should use???
with the size of your domes, i'm guessin that you are somwhere above 1000ft asl. around 30-50 degrees? you should be between 290- 320 mains, a fatter needle will help with the airbox mod, you may need 27.5 pilot jetts. your elevation and temp will help to get you closer
