OK i want to get new pilot jets for my banshee and i want to know what i should get for pilot jets. I have a k&n air filter, fmf fatty exhaust and its been bored out twice. i think my main jets are 400 or 420s. what should i have for pilot jets?
also i dont have any power in sixth gear and i want to try a new sprocket from stock. i think i want to go to a smaller sprocket. what size are stock sprockets and what would be a good one to upgrade to? THANKS!
Edited by monsterarmyriders
ok i checked my sprocket sizes are 41 and 15. now which one should i change and how many teeth up or down?
Stock is 13 in front and 41 out back i think! The higher in front and less in the back gives you more top end!
14/41 stock, you should be around 300-320, and maybey 27.5 pilots. could they be 240's ? that's pretty much dealership jetting. they prefer "power jetting" over proper tuning
i'm running 14/40, and 22/12/9's and it tops out about 80mph. does fine on the trails too.
Edited by AKheathen
ok so a rear sprocket with one less tooth should make a big difference? because I just bog down in sixth gear and its useless. I will take my jets out and let u know what i have and u can tell me what i should have. its been rejetted due to all the stuff i have done to it.
has anyone have close to the same mods as me so i can compare jets?
