lokisbuddy Posted February 9, 2009 Report Posted February 9, 2009 Ok when I get my pro circuts do i have to re-jet right away? I mean if i dont rejet will it be rich or lean? I would rather not have to rejet till spring. or would it hurt my motor thanks Quote
98_shee Posted February 9, 2009 Report Posted February 9, 2009 (edited) You will be lean, wich can burn a hole through your piston. You should rejet!! What is your current jetting? And the pipes are in the mail. You should have them thursday. :thumbsup: :beer: Edited February 9, 2009 by 98_shee Quote
lokisbuddy Posted February 9, 2009 Author Report Posted February 9, 2009 (edited) no idea i did a plug chop and they are paper bag brown so i never pulled em yet. i will most likely wait till spring to put the pipes on then i just wasnt sure if it leaned em out or richend it up I just cant see re-jetting then re-jetting again in like a month. so I will throw em on this spring. Thanks for the deal bro, much appreciated :beer: Edited February 9, 2009 by lokisbuddy Quote
98_shee Posted February 9, 2009 Report Posted February 9, 2009 No problem bro!!! I don't think spring will make much of a difference, I would throw them on and up the jets a couple sizes rejeting is pretty simple. If you don't put them on your gonna be staring at them saying "what if" when your racing those other bikes.......lol Quote
donkeypuncher Posted February 9, 2009 Report Posted February 9, 2009 rejetting your carbs is a fairly easy thing to do. you might as well throw the pipes on now and have the guys on here give you a ball-park idea of what jetts to use. :shrug: Quote
lokisbuddy Posted February 9, 2009 Author Report Posted February 9, 2009 (edited) I live in michigan temps change like 40 to 55 degrees between now and spring. if that doesnt matter then maybe I will re-jet. Edited February 9, 2009 by lokisbuddy Quote
rubberneck Posted February 10, 2009 Report Posted February 10, 2009 40 degree change will more than likely be 2 jet sizes. So if you get it spot on now, you will more than likely have to lean it out 2 jet sizes when it warms up. It is really easy man, dont wait. The power is worth it. Quote
