alky you need plenty of fuel cause you will be burning lot of it .
so either get a pump to keep the bowls full or bigger bowls to hold more fuel or both but would be an overkill
if you do short drag races you could get away with bowls only and remove a float.
they have billet bowls with them
If these carbs are setup to run a pump, it would be in your best interest to run a pump...
The needle and seat are much smaller on pumper carbs because they use the fuel pump pressure, not gravity, to fill them.
While bigger bowls will help, they might not fill fast enough...especially on longer runs.
If you have a picture, we can probably tell you if they're gravity or pumper carbs....
