Tried the jettting board...does not seem to be any action there....
Hello all! Before I start tunning I was wondering if someone can help me get my jetting a bit closer so I have some parts on hand when I start jetting.
Engine info:
535 cheetah with only port cleanup, no race porting etc...
pump gas engine 93 octane
38mm pwk carbs
k&n air filters
big bore drag pipes modifiyed for street use (1" ID outlet at stinger) With silencers (Power pro pipes out of frame)
Im at about 500' above sea level.
mix ratio will probably be stock
Thanks for any hints or help!
Engine info:
38mm pwk carbs
k&n air filters
How far are you racing? Man thats a tough call for me to get that thing even close on gas. Start with a big ass main just to be safe (though you'll probably end up with smaller mains that a 4 mil Cub, etc because of the 10 mil Stroke.)
Maybe 175 mains to start?? Should be plenty fat. I ran 170s (I think) on my 421 with 39 pwks and it was fat. I forget what needle. DEL maybe?? 55 - 60 pilots will get ya going, maybe not perfect, though.
I plan on using it for street riding only, not drag racing..... I plan on using my wideband a/f gauge and will weld a bung in the pipes for tuning...
Just figured I could save some time.
Thanks for the info ;)
