Hello all! Before I start tunning I was wondering if someone can help me get my jetting a bit closer so I have some parts on hand when I start jetting.
Engine info:
535 cheetah with only port cleanup, no race porting etc...
pump gas engine 93 octane
38mm pwk carbs
k&n air filters
big bore drag pipes modifiyed for street use (1" ID outlet at stinger) With silencers (Power pro pipes out of frame)
Im at about 500' above sea level.
mix ratio will probably be stock
Thanks for any hints or help!
  • 2 weeks later...
