04chase Posted January 15, 2009 Report Posted January 15, 2009 im looking into buying a 28.5 jj and a racing hillshooter axle. i have +2 +1 a arms and want to keep it close to the same width in front and rear. im wondering what tires/rim setup would be best to help with the narrow axle. i would go with the play axle but i want to keep it drilled and not run it solid if i can. right now im looking at the st haulers in 21x12x8 but im unsure of what wheels to run or if that will be enough. this is going to be in a stroker of some sort for hillshooting and duning. Quote
bansheefreak Posted January 15, 2009 Report Posted January 15, 2009 i dont think you will find wheels to widen it out that much in the rear... id say get biggest offset you can and mybe some billet hubs that extended 2 inches i think you can get them at rmatv.. but you be better off getting a play axle... Quote
04chase Posted January 15, 2009 Author Report Posted January 15, 2009 i dont think you will find wheels to widen it out that much in the rear... id say get biggest offset you can and mybe some billet hubs that extended 2 inches i think you can get them at rmatv.. but you be better off getting a play axle... yeah i think that may be a better route if i want to do it like this. Quote
