i'm selling my banshee 350cc alcohol/ methanol drag bike i built this one to be light and hold up well to abuse of dune dragging it handles whoops and bumps great it has full suspension on it NOT marvins shaw ridgid shocks it rides great it will wheelie but it is very controled the bike has been lower'd and has a drag shock on the rear and works triple rate's on the front. i do have the stock rear shock and you can raise the front shocks back up for trail and big dune riding if wanted.
350cc engine 65mm bore wiseco pistons all motor new this year., stock cylinder'd drag porting
wiseco crank welded and trued has tz drive bearing on it
hinson billet clutch basket
yfz drag clutch, big springs gpx sling shot locker ( under cover N O bulky cover sticking out!!)
ported stock reeds with boyesen reed's
port matched billet intakes
38/40 packard lectron alky carberators No jets to fool with very easy to tune
k+n filters
redline racing billet heads, custom alky domes
nology coil w dyna programable ignition box custom plug wires br8evix iridum plugs adjustable stator plate
2-5 with 1st duneable override WCR transmission cryo treated by FAST racing
1998 cases with no chain breakage or damage.
FRAME:
lightened original 87 j-arm frame 30 lbs lighter to begin with from an a-arm frame.,
lightened to the point of still being reliable on the dunes ( not EVERYthing was cut out i left some of the min tubes inthe front intact for the shocks to work right.
+2 FORWARD stock width DENTON custom j-arms all new ball joints uses warrior ball joints NO hymes to fall out!
lightend spindles, cut hubs
+6.5 (tdub?) swing arm round carrier style jj+a 35mm carrier original 87 axle ( it is tweaked a lil i have a drag axle onthe way for it.)
cut stock plastics custom seat cover with new firm foam
this bike is fast for what it is i used all the best parts in the motor frame is super straight and i hate to sell it but i need to try and buy a house..
620 259 6178 620 802 8807
NO trades PLEASE i need 4900 out of this..
i can email more pics to someone thats actually interested
