Since OEM heads vary in volume from the factory... The only accurate way would be to face it, then rechamber it with a .035"-.040" undercut and check it for volume with a buret. I would not remove more than about .060" on the facing operation as the aluminum becomes thin in a couple areas. The equivalent volume of a cut OEM head to a 20cc O-ring head would be 19.16cc due to a head gasket volume of .84cc.
