Ok so I chose to run castor 927 in my shee, however there is a problem with this... It says that race fuels or AV gas with a specific gravity of .795 or lower may seperate from the oil at below 35F degrees. I live in Alaska our average temp for the winter is about 20-25F degrees, but we can reach temps as low as -30ish and I won't always be able to park my shee in a heated garage... I know it's not recomended to switch oils because one oil maybe be thicker than the other and cause lube problems, I havn't yet ran it through the motor just lube the crank bearings and cylinder walls with the Castor 927, so can I switch to another oil and be safe if so what is recomended, or what fuel do you recomend because I'll be running race gas unless I drop dome sizes?
hey bud, i thought you checked into the castor additive. anyways, it's ok to switch oils on a newer engine, just iffy on an old one that has run one type it's whole life. it's no secret by now that i really like torco gp-7, but if you got some of the fuel you'll be running, i can add some oil to it in a jar so you can stick it ouside and see how well it holds up. it's supposed to be good any temp, with all fuels :thumbsup: and i can attest how clean it keeps shit inside the engine
The additive does work and if you run a fuel with a higher specific gravity your ok but with the race fuels its harder to find that higher specific gravity, I just want to make sure I'm covered I may try some of that torco since you run it and your not to far away
just lemmie know
