JEFF C Posted January 4, 2009 Report Posted January 4, 2009 CAN YOU DISCONNECT THIS TORS?what does it do?how can i disconnect it?was out ridding to day,running great,,turned it off,would not start up,had to pull start it,got it home and found that i had no spark!!!!!!!!!!! PLEASE HELP THANKS JEFF Quote
F.T.W. Banshee Posted January 4, 2009 Report Posted January 4, 2009 Throttle Over Ride System. Stop the throttle from getting stuck open. No it is not needed but you have to get a removal kit. Quote
98_shee Posted January 4, 2009 Report Posted January 4, 2009 (edited) I done the search for you >Tors removal thread click!!< Edited January 4, 2009 by 98_shee Quote
JEFF C Posted January 4, 2009 Author Report Posted January 4, 2009 THANKS FOR ALL THE INPUT,COULD THIS BE THE HEART OF MY NO SPARK CRAP???? I done the search for you >Tors removal thread click!!< Quote
JEFF C Posted January 4, 2009 Author Report Posted January 4, 2009 had to be pulled by a honda to bump start it,than it ran great but will not kick start ,no spark at the plugs pull start? Quote
98_shee Posted January 4, 2009 Report Posted January 4, 2009 Did you change the plugs? You may need to test the coil and other electricals. Do a compression check on it also. Quote
JEFF C Posted January 4, 2009 Author Report Posted January 4, 2009 i will get new plugs on monday,how do i go about checking all the other electricals,i do not have a manaul yet,what kind of plugs should i get Did you change the plugs? You may need to test the coil and other electricals. Do a compression check on it also. Quote
98_shee Posted January 4, 2009 Report Posted January 4, 2009 i will get new plugs on monday,how do i go about checking all the other electricals,i do not have a manaul yet,what kind of plugs should i get NGK b8es plugs, You should order a clymers manual it will tell you the specs on the electricals. Do you have a compression tester? Quote
JEFF C Posted January 4, 2009 Author Report Posted January 4, 2009 yes i have a compression tester ,how many LBS should read NGK b8es plugs, You should order a clymers manual it will tell you the specs on the electricals. Do you have a compression tester? Quote
98_shee Posted January 4, 2009 Report Posted January 4, 2009 120ish for stock. What are your mods and elevation? Be sure to hold the throttle wide open, make sure you have the rite adapter for the tester. And kick it till the needle stops moving. Quote
JEFF C Posted January 4, 2009 Author Report Posted January 4, 2009 just did a compression test ,only got 60 lbs each cyclinder with throttle wide open,how much is a top end rebuild cost?do not know much about this banshee ,just bought it last week,road for about 2hours,now this .Tell me ,with low compression is this why i have no spark,the shee does have twim FMF fatties,that all i know right now 120ish for stock. What are your mods and elevation? Be sure to hold the throttle wide open, make sure you have the rite adapter for the tester. And kick it till the needle stops moving. Quote
98_shee Posted January 4, 2009 Report Posted January 4, 2009 just did a compression test ,only got 60 lbs each cyclinder with throttle wide open,how much is a top end rebuild cost?do not know much about this banshee ,just bought it last week,road for about 2hours,now this .Tell me ,with low compression is this why i have no spark,the shee does have twim FMF fatties,that all i know right now Sounds like you need to rebuild, if you can, get another tester and test it again just to be sure. With low compression it will make it hard to start, you may be getting spark. You will have to open the top end up and see what you need. Bore and piston kit around here is $300-$350. You should order a clymers manual it will walk you through everything. Quote
[email protected] Posted January 4, 2009 Report Posted January 4, 2009 CAN YOU DISCONNECT THIS TORS?what does it do?how can i disconnect it?was out ridding to day,running great,,turned it off,would not start up,had to pull start it,got it home and found that i had no spark!!!!!!!!!!! PLEASE HELP THANKS JEFF clickly the linky in my sig Quote
AKheathen Posted January 5, 2009 Report Posted January 5, 2009 while you're in there, check out your pickup gap on the flywheel, and ohm the stator Quote
