SO I am close to being done with the rebuild and found a post talking about the guys motor puking gear oil.... This happened to me the last time I rode it and melted the piston.... I think I need to reseal the case again??? I am going to try a leak down test first but is that the only answer, blown case seal?? Thanks!!
ok by resealing the case you mean puting hi temp silicon on the cases right? if so you need to do this everytime you pull it apart the silicon is a gasket to keep all the fluids and fuel where they are suppose to be and not mixing
I had it milled and had the same problem.. I warped it, two seprate heads! I am waiting on a cool head to arrive before I do a leakdown test. I am guessing this is going to give me my ultimate answer... If the seal in the case is ok... what else could make the gear oil puke out?? It also pushed out coolant as if pressure was getting into the water jacket... I think the coolant got into the gear casefirst casue the gear oil was gray...
Edited by hollisatp
ya I dont know maybe the cases are warped alittle or sumthing good luck
