Hey, i have stroker crank, reeds, .20 over, i have 260 main jets now, at sea level, i put these trinity pipes on and i wouldnt start. im guesing i need to go to a bigger jet size??? any help please?
I had a banshee with a 4mm crank and bored .30 over with trinity pipes and I ran a 27.5 pilot jet a 320 main jet and the needle i moved the clip one notch up from the middle.I would say your probably will end up around a 320-340 main on stock carbs with either 27.5 pilots or 30 pilots i hope this was some help for you.
