My right tire is bent. I broke a tie rod and replaced it but the tire is still slanted. The two front tires look like this / l . The top of the right tire is closer in toward the j arms and the bottom of the right tire is poked out. It looks bad and ugly not to mention mewsses with the steering here's a pic i need help asap I'm just a rookie
You either bent a spindle, or bent the J-arm, which is most likely. Post a ad in the wanted section for those parts, And I'm sure someone will help you get back on the trail.
Thanx!!!! That's what I thought a j-arm but I forgot about the spindle
