anyone have any ideas how i can get these 39mm pwks to open all the way... I have the longer carb top screws, and a pro motion cable.. the thumb throttle is hitting the stop on the housing and the inside of the housing..they are about 3/16" from opening all the way... thanks for any help..
Lose the stop on the tumb throttle assembly and tighten the cable as much as you can (without raising the slides) on the bars. It's sometimes a fight between being able to open the slides up, and having them open before you ever give it gas. Good luck.
thanks ill try it...heading to the garage with the hacksaw....
