i got an old digitron egt unit that i plan to install on the shee. how far from the cylinders are the probes supposed to be mounted? some people say 8 inches from the piston? is this correct? anyone else run these on thier bike?
i had em mounted 6" away from the piston on my sled motor, but i wasn't sure if the distance was applicable to two stroke bike engines. i just figured differences in displacement and pipe diameter may make a difference in where the probes were positioned.
sorry my bad! I miked the distance and it is actually 3.77 inches.... :geek: and the are drilled on the inside of the pipe pointing outward so that the springs and tabs are not in the way....if that makes any sense :confused:
