banshee#44 Posted September 28, 2008 Report Posted September 28, 2008 ok ive had this quad for 2 weeks now , i ride up and down my street and when i come back im dumping gas out of my carbs overflows, i took the banshee down to the place i bought it at cause they said they could fix it. they put in new seats and needle jets in the carb. i got the quad back 2 days ago and it still just as bad as it was before. WHAT DO I DO NOW!!!!! Quote
THE GRIM RIPPER Posted September 28, 2008 Report Posted September 28, 2008 Take the carbs apart.... (Bowl off) remove the pin holding the float on. carefully remove the needle, then submerge the floats in water and check for pin holes. (there shouldnt be any fluids at all in the floats) then do a search and find the measurement @ which your floats should be positioned when re-installed. Quote
banshee#44 Posted September 28, 2008 Author Report Posted September 28, 2008 Take the carbs apart.... (Bowl off) remove the pin holding the float on. carefully remove the needle, then submerge the floats in water and check for pin holes. (there shouldnt be any fluids at all in the floats) then do a search and find the measurement @ which your floats should be positioned when re-installed. ok i'll give it a shot thank you for the help Quote
