yamshe Posted September 27, 2008 Report Posted September 27, 2008 i need lower axle carrier bolt/nut the clutch cable stay bolt (on the case) and a front right motor mount bolt the one that conects the "dog bone" motor mount to the frame from under the motor i need theis things shipped to 53711 for as cheap as possible i could also use a set of head lights if they are cheap enough but i realy need the hardware thanks for your help Quote
