wacko2000 Posted September 16, 2008 Report Posted September 16, 2008 Like it says, my bike wont shift from 3-4 4-5 5-6, the lower gears are okay i guess. I was wondering if they sell stronger forks, im goin to be splitting the cases for the 4mil and would like to replace them and the shift shaft. There is a member here that runs rz shift forks, any info on these would be great.. thanks Joseph Quote
yamshe Posted September 16, 2008 Report Posted September 16, 2008 that happened to my shee 1 and 2 were fine but it would not shift into 3rd or higher it was a sping and bushing in side the trans like 15 dollars worth of parts. it shifts great now Quote
wacko2000 Posted September 16, 2008 Author Report Posted September 16, 2008 that happened to my shee 1 and 2 were fine but it would not shift into 3rd or higher it was a sping and bushing in side the trans like 15 dollars worth of parts. it shifts great now was it the shift shaft, spring and bushing that was causing the problem? thanks joseph Quote
houdini Posted September 16, 2008 Report Posted September 16, 2008 same thing happened to mine, i already have a modded shift star, so i replaced the shift shaft with a new stock one and then i bought a shift pro kit. it comes with a spring with less tension and a roller bearing . fixed mine, and ive got a 4mil with a lockout clutch. my fix cost around 120.00 its well worth it. Quote
