98_banshee_newbie Posted September 12, 2008 Report Posted September 12, 2008 Now when guys are talking dual 33mm carbs is that equal to a 33mm 2n 1 33mm carb? If not what would a 33mm 2 n 1 be equivalent to? Quote
Wildcard2 Posted September 12, 2008 Report Posted September 12, 2008 The 2into1 setups mean that 2 cylinders are bein fed by one carb....so there would be only one 33mm carb vs. having 2 33mm carbs. Hope that helps. Quote
98_banshee_newbie Posted September 12, 2008 Author Report Posted September 12, 2008 Right, I do understand that. That is what I thought I just did not know if the volume of fuel/mixture would be doubled for say to equal what a dual carb setup would produce. I quess I am thinking of it as 1 33mm carb per cylinder compared to 2 cylinders running off one carb would be like 16.5mm per cylinder if using a 33mm carb. Quote
