andrew3160 Posted March 17, 2010 Report Share Posted March 17, 2010 Need to buy some new wheels for my sand tires. Not sure on the size to buy. 10x6 on the front are kind of hard to come by. Rear paddles are 20x11x10 and front dune runners are 21x8x10 Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted March 17, 2010 Report Share Posted March 17, 2010 Well you should be fine on stock wheels. Or even some Douglas blue label .125's if you don't jump big.Or if you want more strength go with the red label .190's Or theres quite a few from ITP also. I run the T-9 Pro Baja .190 wheels and i love them. Also you don't need a 10x6 front, you need 10x5's! Quote Link to comment Share on other sites More sharing options...
andrew3160 Posted March 17, 2010 Author Report Share Posted March 17, 2010 Well you should be fine on stock wheels. Or even some Douglas blue label .125's if you don't jump big.Or if you want more strength go with the red label .190's Or theres quite a few from ITP also. I run the T-9 Pro Baja .190 wheels and i love them. Also you don't need a 10x6 front, you need 10x5's! Thanks Savage. do I need 10x8 or 10z9 for the rears? Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted March 17, 2010 Report Share Posted March 17, 2010 FYI, the wider your wheels, the wider the footprint of your tire and the less they sink in the sand. I used to run 10X7 on the front and 10X10 on the rear until I went back to the stock 89 wheels. I went back to the stockers because I was having to much trouble bending Blue Label wheels, even my wife bent her's and she barely gets off the ground. With the stock wheels, I have far less problems with bead leaks also. I would highly recomend a wheel with a rolled bead to prevent leaks, as thick of a wheel you can afford in 10X7 and 10X9 sizes. I run the same size tires. Quote Link to comment Share on other sites More sharing options...
andrew3160 Posted March 17, 2010 Author Report Share Posted March 17, 2010 anyone have a good set of wheels that would work for those Tires. I would need the read hubs too if it is off 91+ banshee. I just need something that will hold air and are clean looking. G Force makes a sweet wheel just cant find them in rears Quote Link to comment Share on other sites More sharing options...
MN SHEE Posted March 17, 2010 Report Share Posted March 17, 2010 got a set of gold ones (stockers) lmk Quote Link to comment Share on other sites More sharing options...
andrew3160 Posted March 17, 2010 Author Report Share Posted March 17, 2010 Rear Tire= 20x11x10 get 10x9 wheel with 3+2 off set Front Tire=21x8x10 get 10x6 wheel with 4+1 off set Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted March 18, 2010 Report Share Posted March 18, 2010 Rear Tire= 20x11x10 get 10x9 wheel with 3+2 off set Front Tire=21x8x10 get 10x6 wheel with 4+1 off set Your offset numbers don't add up. The 2 numbers of the offset should add up to the width of the wheel. Also, most aftermarket front wheels are either 5 or 7 inches wide, it is very difficult to find aftermarket front wheels that are 6 inches wide. Most wheel charts say the stock wheels are 6 inches wide and the recomended replacement is a 10X5 wheel. Quote Link to comment Share on other sites More sharing options...
