dragbanshee Posted August 19, 2008 Report Posted August 19, 2008 I need new k&n pods for my oko's/kehins carbs, anybody know where to get these? 28mm Quote
docjcwatson Posted August 20, 2008 Report Posted August 20, 2008 I just got mine today for my 40mm Mikuni's. I had to order them through the stealership. Doesn't matter where you go. Just need to make sure you tell them the I.D. (Inner diameter) and the O.D. (Outter diameter). Plus the length that you need. Good luck! :thumbsup: Quote
dragbanshee Posted August 20, 2008 Author Report Posted August 20, 2008 I just got mine today for my 40mm Mikuni's. I had to order them through the stealership. Doesn't matter where you go. Just need to make sure you tell them the I.D. (Inner diameter) and the O.D. (Outter diameter). Plus the length that you need. Good luck! :thumbsup: Thanks man I may have to do that if I dont find them anywhere else. Quote
BURRITO Posted August 20, 2008 Report Posted August 20, 2008 Just get pods for stock carbs...The 26mm fill fit on your 28mm just fine, thats all I ever ran when I had mine. Now I run 34mm and get my pods from Cascade... I think you will save some $$$$ if you just run the 26mm.... Quote
