atvfreestylekid Posted July 14, 2008 Report Posted July 14, 2008 I just recently had to replace the little adjuster bolt on the shifter behind the clutch cover. Now it won't shift worth a f***. It does not shift well up or down. will the bolt not being adjusted right do this? I figured it would shift better one way than the other if it was not adjusted right. It seems to shift better without using the clutch. But sometimes i will bring the lever up 3 or 4 times before it will shift. It did not do this before. Quote
dsmrx7 Posted July 14, 2008 Report Posted July 14, 2008 Have you tried adjusting the cable at the lever? Quote
KaosBanshee44 Posted July 14, 2008 Report Posted July 14, 2008 You talking about the adjuster on top of the cases? Quote
badassbanshee479 Posted July 14, 2008 Report Posted July 14, 2008 they will not shift worth a crap if it is not adjusted correctly. Do you have a cylmers to see how to adjust it? If not I can try and explain it for ya if you want. Let me know Quote
atvfreestylekid Posted July 16, 2008 Author Report Posted July 16, 2008 Yeah I have a service manual. I adjusted it as good as I could. It is very close. Could there be somthing else screwed up? Quote
