Hi i was wondering what main jets and the position of everything else needs to be. The bike is completely stock. I will be adding a KandN and most likely using no lid. I am at 52 feet sea level and go to pismo so it shouldnt make to much of a difference.
Go up 3 to 5 sizes on the main jet (Probably 230 to 250) and turn the air screw in 1/4 turn. Start there.
....X2.
i would also leave the needles alone (clip in middle position) and stock pilots in for now. just play with the airscrews and if it is still lean after turning the airscrew in, so its only 1/2 turn out from closed, than bump up 1 size on the pilots and go back to 1-1/2 turns out with air screws and fine tune from there.
