Banshee Time Posted May 28, 2008 Report Posted May 28, 2008 2002 Banshee built from the ground up. Converted to Motion Pro twist throttle so I have installed the idle screw kit. I have to use ether to get it started even after it warms up. What am I missing here? Sounds like I am not getting fuel. ACE Quote
Dinner Posted May 28, 2008 Report Posted May 28, 2008 Probably something to do with your pilot jet. What is your current jetting, style of carbs, mods, and temp/elevation? Quote
Banshee Time Posted May 28, 2008 Author Report Posted May 28, 2008 2002 Banshee built from the ground up. Converted to Motion Pro twist throttle so I have installed the idle screw kit.I have to use ether to get it started even after it warms up. What am I missing here? Sounds like I am not getting fuel. ACE Stock carbs, FMF pipes and SST used jets from that came with the pipe kit. Temp is 90 degrees and elevation in Richardson Texas I do not know. Quote
Banshee Time Posted May 28, 2008 Author Report Posted May 28, 2008 2002 Banshee built from the ground up. Converted to Motion Pro twist throttle so I have installed the idle screw kit.I have to use ether to get it started even after it warms up. What am I missing here? Sounds like I am not getting fuel. ACE We know how difficult jetting can be sometimes, that's why when we test our exhausts we also adjust the jetting to see what works best. Sometimes stock jetting works fine, other times a slight adjustment is needed. Here is what we've come up for in our area and is a great starting point for you as well. There are way too many variables in jetting to give you a recommendation that works perfect. Use these specs for a reference to help aid you with your specific bike. We developed these specs with a 32:1 fuel to oil mixing ratio of a 50/50 mix of race fuel and super unleaded, 0 - 1500 ft altitude at 70 degrees outside temperature. Your choice: YAMAHA --> 2002 --> BANSHEE Select another bike Jetting Information Main Jet: 260 Pilot Jet: N/A Needle: STOCK Needle Position: 3RD Power Jet: N/A Air Screw: 1.5 Fuel Screw: N/A Comments: Remove airbox lid snorkel Quote
dajogejr Posted May 28, 2008 Report Posted May 28, 2008 I thought that was a damn good explanation on their part....honestly. How did you adjust the idle screws you just installed? Did you completely unplug ALL Tors wiring and hardware? Quote
Banshee Time Posted May 28, 2008 Author Report Posted May 28, 2008 I thought that was a damn good explanation on their part....honestly. How did you adjust the idle screws you just installed? Did you completely unplug ALL Tors wiring and hardware? We adjusted those back and forth it did not make a difference in starting. It will not start on its own. TORS never existed and not plugged in. Quote
dajogejr Posted May 28, 2008 Report Posted May 28, 2008 You need to make sure turning the idle screw in actually raises the slides. Please confirm that before we go further!! Quote
Banshee Time Posted May 28, 2008 Author Report Posted May 28, 2008 You need to make sure turning the idle screw in actually raises the slides. Please confirm that before we go further!! OK, will get back to you. Quote
Erwin8r Posted May 29, 2008 Report Posted May 29, 2008 OK, will get back to you. Also, check the basics: float bowl level, make sure the carbs are clean, make sure your petcock is flowing fuel, etc. Quote
Banshee Time Posted June 2, 2008 Author Report Posted June 2, 2008 Also, check the basics: float bowl level, make sure the carbs are clean, make sure your petcock is flowing fuel, etc. Idle screws move the slides up and down. The carbs are brand new but will check the jetting. Quote
