ok took the banshee out today and had a few problems, all of which i fixed except for one i could not figure out. my clutch would work/not work at random times. there would be no tension when i pulled the clutch level and everything was moving but nothin was happening. decided to ride it like that for a while and all of a sudden it was fine. did this thruout the day on and off. anyone have any idea what this could be or have had this happen to them? im thinking its something to do with the shaft the pushs the clutch rod. thanks for any help before hand.
Do this, pull the plug smell the oil ( i know hear me out) if its rank the clutch is fried that would give you the spastic clutch
ok but the clutch has 1 run on it. its brand new. the kid i bought it from put the clutch in wrong and we redid it. is there something i could have done wrong? thanks for the help tho. anyone else?
[ That shit happened to me i just fixed it well i cranked up a hill and my hand had the clutch in but was still pulling and then i had no tension. the washer that holds on the clutch basket bolt. right? the washer has like three tabs you fold over to lock the nut. Check your washer it may have been a worn washer folded to many times or not thick enough i fabricated my new washer which was a 16th bigger no telling though. IM TELLIN YA at least look that sounds like it and if it is thats a easy fix
they thanks for the input. ill check that in a few days when i have time to open it up. ill post my findings as well.
