SQUIRREL MASTER Posted April 21, 2008 Report Posted April 21, 2008 my rear brakes lock up on me everytime that i ride over 30 minutes or when bike is a little hot. i put a new steel braided brake line and bought a repair kit and installed it. bike still locks up and the brakes release after 10-20 minutes. does anyone know what happening? or what can i do to fix this problem? Quote
hollisatp Posted April 21, 2008 Report Posted April 21, 2008 I would check to see if the line is clogged somewhere ? When you start out riding does it work properly for a bit then locks up? Quote
dajogejr Posted April 21, 2008 Report Posted April 21, 2008 Get another caliper used, when the pads come off, are they worn even or at an angle? Something could be bent back there making the pads rub more than they should... Quote
sa3ood_banshee Posted April 21, 2008 Report Posted April 21, 2008 lol looks like u like 2 watch half baked sa3ood Quote
SQUIRREL MASTER Posted April 26, 2008 Author Report Posted April 26, 2008 I would check to see if the line is clogged somewhere ? When you start out riding does it work properly for a bit then locks up? brakes work fine for the beggining of my ride and then later they get locked. Quote
SQUIRREL MASTER Posted April 26, 2008 Author Report Posted April 26, 2008 Get another caliper used, when the pads come off, are they worn even or at an angle?Something could be bent back there making the pads rub more than they should... when i take the pads off they look even. i originally changed the caliper before the repair kit and steel braided brake line. before they lock they work perfect so im not sure about something something being bent. Quote
