I recently popped the chain, and i had no case saver and this is a result,
nothing is leaking, or anything its just that top piece that is gone what could i do? or how should i fix it
If it was me i would use jb weld. I know a couple of people that have cracked their cases and they leaked gear lube and jb weld sealed it up and they never had a problem with it.
nice ill go ahead and go with some JB weld, what about a chain? whats the best chain and how many links would it be if its stock swing arm 14t front and 41 t back
go to ebay u can get sprockets and chain together for like 65.00 to 80.00 and u get get them in colors. they are good chains and sprockets.
The damage is already done. J.B. weld will do nothing but make it look a little better. as long as theres no leaks, let it go.
Another idea is to trim the busted area with a die grinder, you could make it look better, ( less noticable) I've done this to a few bikes in the past.
There is no way I would skimp on the chain. If you get one off of ebay buy a good chain not a no name brank.
I would grind it flat before anything. Thats a big hole to just put jb weld on it. Try to get a thin piece of alum to cover the hole then jb weld around it. Or you could just have someone weld it but I dont think its going to need it because there is not much pressure in the gear side. Either way it makes me happy to have a case saver!
lol thats nothing! i should post a pic of my case. The chain went on the previous owner and took everything clean off. It dosent leak and the stator side is all good but took off all the mounts around the sprocket
hi my name is tood d messer if you want them welded up its not that big of a job you can call me or email me you send me you cases and ill weld them for 65 +ship back cost [email protected] 14798463668 is home thanks ls409
