bansheejoel Posted March 20, 2008 Report Posted March 20, 2008 (edited) i know a guy that has a set of brand new chettah cub cylinders. He said there 392cc with a 68mm bore. is that right? or have they been bored? he only wants $400 and he said they have never been used, is that a good deal? he said there stock stroke..so those will fit on my shee with no modificatons right? thanks Edited March 20, 2008 by bansheejoel Quote
sheerider1026 Posted March 20, 2008 Report Posted March 20, 2008 yep. its a 392cc.. thats the same cub that i have. stock stroke 68mm bore.. they come with a 68mm bore.. you on't bore cheetah cub cylinders, you have them replated when they need it.. and yes.. 400 bucks is a steal !!!!! it is a bolt on and go deal, you will need big bore domes though.. and of course bigger carbs, shearer or cpi pipes, Quote
J-Madd Posted March 20, 2008 Report Posted March 20, 2008 Yeah that's a great deal. Not bad even if they were used, as long as the nikasil is in good condition. You'll need to get your crank trued and welded eventually though. Other than that and the BB domes, you can bolt on and go. You'd eventually want bigger carbs, pipes, extended swinger, etc. Quote
