Blue IMS 4 gallonTank plastic bridge was cut to fit a Dual Pingle, Stock petcock will still fit and seal fine with the rubber gasket ( NO cap or petcock ) $150 shipped within upper 48 states
Stock Coil $50
Lower Motor Mounts $15
Brand New EK Non O-Ring Chain with Master link. Long enough for a +6. I think I counted 130 links. Brought this last year and decided to run a Sidewinder instead. $75
New Upper A Arm Bushings $25
12 New Delron Bushings for A Arms $25
Marvin Shaw Spacers for ront shocks $5 per pair. Have 4 pairs
Stock Clutch Cover No impeller bearing, seal, or water pump cover $20
If you wish to use Paypal You add 3% for fees. If not I will take money orders.
All parts plus shipping. Unless other wise stated
Edited by Bansh-eman
probably a dumb question but how do the stock plastics work with tthat tank?
not a dumb question at all.. using this tank you simply take off the stock tank cover and the rest of the plastics remain unchanged. Alot of other brand tank and every other tank larger then 4 gallon requires you to cut the front plastic so the tank can fit.
you can see very well but both banshees in this pict have one of those tanks.
