tidos76 Posted February 29, 2008 Report Posted February 29, 2008 ok this might be..... ok is a noob question. what is syncing the carbs? and how do you do it? I know my carbs are set right i am just brain farting about the termanology. Quote
dragbanshee Posted February 29, 2008 Report Posted February 29, 2008 ok this might be..... ok is a noob question. what is syncing the carbs? and how do you do it? I know my carbs are set right i am just brain farting about the termanology. Dont know about "Termanology" but checking your slides to make sure they are opening & closing at precisely the exact same time, in sync. The adjustment is on top of carb where cable meets cap, depending on carbs. Quote
kawiking Posted February 29, 2008 Report Posted February 29, 2008 jeff at F.A.S.T. sells a tool that will make it easy . well worth the money !!!!!! Quote
xsinnerx Posted February 29, 2008 Report Posted February 29, 2008 jeff at F.A.S.T. sells a tool that will make it easy . well worth the money !!!!!! is there specific rpms besides at idle that you check?? Quote
jmd0346 Posted February 29, 2008 Report Posted February 29, 2008 Ive always done mine by eye. Keep adjusting untill both open at the same time. Make sure they both open all the way and youve got it. I dont see the need for a tool to do this. Im wrong on things from time to time so if someone can please enlighten me on the need for a tool Id appreciate it. Quote
rubberneck Posted February 29, 2008 Report Posted February 29, 2008 I check them at idle and get them even using the idle screws on the sides of the carbs (tors removed) Then i screw the cable adjuster at the thumb throttle out until the bike starts to rev up a little. Next adjust the cable adjusters on the carb cap untill the carbs are even again. This makes sure that the carbs are in synch at idle and in synch when you hit the throttle. Screw the cable adjuster at the thumb back in until you have about and 1/8 inch of free play at the thumb throttle and you are done. Quote
