First all I really like the forum. I bought a banshee a couple of weeks ago. Has some issue's I want to take care of before I ride it.
First is the rear break. the one on it is toast. The idoit that had the quad wore the pads out. So he took the caliper off and straped it to the say arm. Which inturn pop the piston out and lost it. (what a moroon). So what question is. Will a caliper off a blaster 2003 newer work without any mods.
Second is the control unit assy. I believe that's what is call. It right under the tank on the left side if your on the quad. It has 3 wire plug. I got looking at it and its not plug in. What is it for and does it hurt the perforance of the quad.
Thanks in advance. Ez
Newer Blaster or a Warrior or a 660 Raptor rear brake caliper fits a Banshee. The small box is the TORS control unit, it is used to kill the ignition if the throttle slides are open when the thumb lever is not pushed. Most people unplug the unit to prevent electrical problems and sometimes remove the other components. The wire going to the thumb throttle and the large bulky aluminum contraptions attached to the carbs are also part of the TORS system.
